Hi all!
Is there a way to deactivate comments for open issues?
I have tried jira.permission.comment=denied but it didn't work.
We are using jira software, version 7.9.2.
Iro
Can you try :
jira.permission.comment.denied=true
This should work.
Elifcan
This works for us; note that you need to add this property to every status that you consider to be open (for which you don't want comments). Perhaps in your test case your issue had a status other than the one for which you added the property.
I have added this property to Open status. I click on publish button to save changes and now here is what was showed up when i selected an issue.
You are adding the property like this, correct?
I tested it myself and it's working without a problem. Maybe check out the logs if it doesn't work?
Elifcan
Hi!
It finally worked! I missed a "."...
Thanks a lot!!
Iro
