How to desable Jira Work management
Serge Calderara
Dear all,
I have run a Jira Cloud trial instance in order to evaluate some stuff difference between my customer Jira cloud instance.
Then what I notice new is this Work Management view when creating project other than Software and Service management
Is there a way to remove that Jira Work Management Layout from Jira cloud trial ?
Or is is fully imbedded and cannot be removed ?
Thanks for your reply
regards
BHUSHAN PATIL
February 13, 2024
Hi @Serge Calderara ,
We have a similar question regarding this. Please refer to:
How do I remove Jira Work Management from Jira Cloud completely?
Bhushan
Serge Calderara
@BHUSHAN PATIL ,and no solution or reply yet ?
I have the feeling that it is fully embeded to this new Work management view design
