How to disable comment for closed issues ?
Deleted user June 8, 2018
How to disable comment for closed issues ? I'm using jira 7.6.4 and  have tried  jira.permission.comment.user = denied/false , none of them worked for me.
Bastian Stehmann
Hi @[deleted],
just try jira.permission.comment=denied
based on this document
https://www.j-tricks.com/tutorials/permissions-based-on-workflow-status
Deleted user June 11, 2018
Hi @Bastian Stehmann ,
This is for old version , not working for 7.6.4 version.
Fazila Ashraf
Hi @[deleted]
Following this document -> https://confluence.atlassian.com/jira063/how-to-deactivate-comments-for-closed-issues-683542388.html , try  jira.permission.comment.denied="
Hi @Fazila Ashraf,
Its says not a valid value.
Fazila Ashraf
Hi @[deleted]
I actually tried it now..
Setting it to true like below does the trick for me :
Ollie Guan
Hi @[deleted],
Can you try the following solution?
1. Create a user group xxx, which does not contain anyone
2. Workflow configuration: jira.permission.comment.group= xxx
Hi @Ollie Guan
It didn't work for me. Thanks for your reply.
