How to display dynamic fields based on jira Custom field Cascading field type(Using Parent values)?
Varun Nelluri April 29, 2020
We are using script runner and i have create few behaviours for Single select or multi select dropdown fields to display dynamic fields.
I am not sure how groovy script works with Cascading field, Could you please some one help me how to display dynamic fields based on Cascading field primary values(Groovy code much appreciated).
Below is the sample  groovy code i have written to  display dynamic fields(Drop Down (Single))  on Field:
def ProblemCodeFieldValue = ProblemCodeField.getValue()
if (ProblemCodeFieldValue == "x") {
CallSamplesField.setHidden(false)
AccountNumberField.setHidden(true)
if (ProblemCodeFieldValue == "XX") {
CallSamplesField.setHidden(true)
AccountNumberField.setHidden(false)
if (ProblemCodeFieldValue == "XXX") {
if (ProblemCodeFieldValue == "XXXX") {
Joshua Yamdogo @ Adaptavist , @Jenna Davis , I see all of you solved a couple of similar behaviours questions before, could you possibly help me with this one please?
Andre Serrano
May 6, 2020
Hi Varun,
have you checked Adaptavist Library website?
https://library.adaptavist.com/
It's a library of groovy scripts that you can use on your ScriptRunner.
I was checking there and I think this script can help you getting where you want:
https://library.adaptavist.com/entity/set-behaviour-multi-and-single-select-options-and-value
Varun Nelluri May 6, 2020
@Andre Serrano , I did but i couldn't find the dynamic fields display based on the Cascading field values.
SERVER
