How to display linked jira issues to a single macro?
Tony Montana
January 10, 2019
subj
Taranjeet Singh
@Tony Montana Can you be a bit more clear and tell me what do you exactly want to achieve?
See this Atlassian document on "JIRA Issues" macro to check if any of the information is applicable to provide you the desired solution for your ask : https://confluence.atlassian.com/doc/jira-issues-macro-139380.html
Let me know if you are looking for something else in this regard.
Tony Montana
January 10, 2019
JIRA Issue Macro - its manual work
JIRA Links (top on page) - its auto-connect view
We need the macro to display style JIRA Issue but as auto connect JIRA Links Viewer on a pages
