How to display weekwise statistics gadget in JIRA
nagaraja ballal.c
December 7, 2018
I have created a filter where it will display stats for previous week. I used functions createdDate >= startOfWeek(-1w) AND createdDate <= endOfWeek(-1w) in JQL and displayed result in issue statistics gadget. Now when i see on sunday it will display stats for previous week(i.e Sunday to sat). Now i want this gadget to display previous to previous week stats as well. Like week 1 stats based on severity, week 2 stats based on severity.
Ismael Jimoh
December 8, 2018
Try
created < startofweek() and created >= startofweek(-2w)
nagaraja ballal.c
December 8, 2018
Thank you for your reply. Here its showing issues which are created 2 weeks before Dec 2nd (Nov 18th till 1st Dec) . Now i have represented this filter in issue statistics gadget based on issue severity. Now tomorrow since its start of the week it will display from 25th Nov till 8th Dec. But my manager wants to see 2 weeks prior to that also in the same gadget. He don't want it to get erased so that he can compare stats between these 2 weeks. Is there any way to achieve these via gadget?
I know that we can create filters with dates hard coded dates in JQL and add it to gadget. But is there any way to achieve it other than this manual method.
Ismael Jimoh
December 11, 2018
No there is no ways I know to achieve this dynamically.
At best, you can create 2 different filters one for past 3 weeks the other for past 2 weeks if you need to see issues from much earlier.
