How to dynamically populate custom field with values from excel
Maryam Nadir August 3, 2022
I need help!!!
I am new to JIRA...and I am setting up a new project.... One of the custom fields in my issue needs values to be populated from excel sheet.
I have no clue about how to get this done
I would be grateful if some kind soul guide me on this
Bharathi
August 5, 2022
Hi @Maryam Nadir,
Since you've mentioned that the list of users in the excel are the employees of your organization, if you need them all to be onboarded to Jira as well, you can check the possibilities of turning on automatic Jira access for all new hires which will in turn onboard them into Jira. This will in turn keep the user base up to date.
The custom field can then be configured as a user picker field which can automatically fetch its values from Jira's user base.
Thanks!
Maryam Nadir August 4, 2022
@Nic_Brough__Adaptavist_ I saw you reply in one of the threads. Could you kindly help
Sebastian Krzewiński
Hi @Maryam Nadir
Do you need to add value to custom field in issues or you need to set values for custom field?
For add values in issues you can use csv import - https://support.atlassian.com/jira-cloud-administration/docs/import-data-from-a-csv-file/
Seba
Maryam Nadir August 4, 2022 edited
Thanks a lot for your reply!
I need to set values to custom field... like when creating new issues, this custom field should fetch values dynamically from a excel or csv file.
Julie d_Antin _Elements_
Hi @Maryam Nadir
Are the values in your Excel/CSV file being regularly updated by people? Or is it just that the list of values is very long? Is that the reason you don't want to add the custom field options within Jira?
You mention fetching the valus dynamically: do you need to set the value of the custom field based on another field? For example, if component is X, set custom field to Y ?
Yes, you are right...the values of EXcel/CSV gets updated regularly. It basically has the list of employee names of my organisation.
Radhika Rajendran May 7, 2024 edited
@Maryam Nadir Did you get answer for this? I exactly have the same requirement.
Like • Charlotte MacRae likes this
Charlotte MacRae
June 7, 2024
Ditto!
Allison L Wenner November 5, 2024
Was there a solution for this?
