How to edit jira view screen when you click on backlog item
Rajat April 13, 2020
Hi All
When you click on any issue in the backlog, a small screen appears with issue details.
We would like to edit the layout of this screen in our JIRA SERVER.
Is this possible? If yes, how?
Regards
Rajat
Monika Rani
Hi @Rajat
Yes, It is possible. You can edit this side issue view by following these steps.
1. Go To Board Setting "Configure" option from the top right corner
2. Go To "issue details view" option from the left menu.
 3. Simple drag and drop the field name according to your requirements or you can add the more fields also if you will not find anyone that you want to keep.
You can add new fields from the Top.
Rajat April 22, 2020
Thanks @Monika Rani for the reply but may be I was not clear in my requirement.
What we would like to reorganize is the sections and not the fields inside it.
Example, we would like to move Subtask section above the Description section or Attachment section just below the Details section.
Is this configurable?
Rajat
Monika Rani
Hi @Rajat,
I don't think so it is configurable, you can configure the fields only, not the sections.
Please mark the answer accepted if you found my explanation useful.
Monika
