I created a new project and in permissions allowed people on my team to browse it and be assigned to issues. However, when I go to the "project settings->people" and choose to add people, it allows me to only assign them to the admin role. How I can add more roles to the project, so it allows me to add people to the project with other roles?
It sounds like you haven't defined more project roles. Project roles are universal, not defined by projects.
You need to define the Project Roles under the Admin area. Go to Administration -> System, then under the "Security" heading you should see Project Roles
Thank you!
Can you mark the answer accepted if it works? :-) Thanks
