How and where do I find "Linked Issues" field. I am not able to view that field under "Custom field" page. I need to add a value to the existing list in "Linked issue" field. How can that be achieved?
Linked Issues is not a field. Linked Issues is a dynamically generated list of issues that are linked to a given issue. You would need to use the issue linking functionality to add another link between your issue and another issue.
Thanks! that helped. Issue linking feature it is!!
Where do you need to add a value? Could you send me a print of the existing values?
Regards
Thank you.. I was able to figure this out. Was able to add the values from "Issue linking" tab.
