How to enable Roadmap in existing Project
neha gautam October 19, 2021
Hi ,
I am working on a project, for which we have two separate board for 2 different module. Now, as per the steps, I'm trying to enable roadmap for each board but going to board setting of each module, no option as Roadmap is available to enable.
Not sure, where I am wrong. I have administrator right but not the owner for board.
Pls help.
John Funk
Hi Neha,
Can you get to Board settings? The 3 dot menu on the top right of the board.
Once there, you should see Roadmap on the left-hand side.
@joh
I don't have 3 dot, instead I have navigated through these steps-- Board>> Configure>> and then it navigate to board setting where Roadmap is missing. Please refer the screenshot.
John Funk
Ah, it sounds like you are on Jira Server then and not Cloud. I don't believe the that feature is available yet in Jira Server.
Like # people like this
Thanks @John Funk @Robert Wen_Cprime_
Actually, I am looking for creating Gantt chart for the epics and story.
One quick question, do we anything know as Wiki provided by Jira? As I can see that integrated.
Robert Wen_Cprime_
The "wiki" is Confluence.  If you have Confluence installed, you can connect the two together.
Robert Wen_Cprime_
Hi @neha gautam !
Can you elaborate if this is for a team-managed project or a company-managed project?
Hi, @Robert Wen_Cprime_ It's company managed project.
Manon Soubies-Camy
Hi @neha gautam and welcome to Community!
Can you check in your Project settings > Features if Roadmap is enabled?
Hope this helps,
- Manon
@Manon Soubies-Camy , I am not able to find features under project setting.
