I have administrator privilege for a project and when try to filter using "istriaged" field for issues. It shows disabled hence unable to get the filter. Please let me know how we can enable it?
Hello @Karthick
Thanks for reaching out to the community.
You can refer to below steps and let us know if that works.
Step 1: Locate the Field
This will provide you with a table displaying the field’s status and any admin-related settings that might be affecting its visibility.
Step 2: Modify Field Configuration
Note: You need to be a product admin for Jira to be able to make changes to Field Configuration.
Let me know if you have any questions.
Hey @Karthick
Thanks for writing back.
To implement the changes mentioned above, you need to be a Product Admin. Please reach out to the Product Admin for your site.
Since you are not the Product admin, you won't have access to the user management tab. I recommend reaching out to someone in your organization who manages Jira; they should be able to assist you with this.
