How to enable "Deployments" section of a JIRA project?
peter gusev November 28, 2024
I have pipelines set up in Bitbucket repo which is linked with the JIRA project. I can see that they run on every commit, I see them run on every feature/fix branch as well:
But, why am I still seeing this screen in "Deployment" section of the project?
Humashankar VJ
December 2, 2024
Hi @peter gusev
Thanks for the insight,
To activate the "Deployments" feature in JIRA, ensure that at least one deployment notification is sent from your CI/CD system to JIRA. Verify that your Bitbucket pipelines are properly configured to send deployment notifications to JIRA, triggering the feature to become active and visible.
For more help - What makes a Deployment appear in Jira for a speci...
Best Regards
Humashankar VJ
November 30, 2024
Hi @peter gusev
Give a try with this help article to get things aligned.
Enable deployments | Jira Cloud | Atlassian Support
What is the deployments feature? | Atlassian Support
Hope this helps - Happy to help further!!
Thank you very much and have a great one!
Warm regards
peter gusev December 2, 2024
Hi @Humashankar VJ
Thanks for your reply!
Unfortunately, the help articles are useless. They basically, repeat each other saying that these three things should be done:
> "Enable or disable the deployments feature" in the project settings
This is already done, as can be seen in my question, since I can open the "Deployments" page, which means "Deployments" has been enabled.
> Connect your deployment tool to Jira
Which is also done, since you can see the feature description hooks up into Bitbucket's branch, as well as Bitbucket's pipeline, which can be seen from the successful build I highlighted in the screenshot.
Your team must then reference issue keys in commits, branch names, and pull requests, to start linking code and deployment information to Jira.
This is also done, as seen in the issue description -- it can successfully identify with a feature/bug branch and the pipelines that run on that branch.
> View deployment information in Jira
> Once you set up a deployment integration, the Deployments page will show all the deployments linked to your issues, displayed over a timescale. You can filter by environment, version, epic, and issue type, or change the date range.
And this last bit never happens, even though all the rest integrations are working. That's my question - why?
Like Humashankar VJ likes this
