How to enabled Issue Navigator to use Better Excel Reporter add on?
Scott Simpson June 12, 2024
Our team has recently added the Better Excel Reporter add on within JIRA to be able to extract reports on issues. To use this app, you need to enable the issue navigator. Everything I read tells me to enable to issue navigator within project settings > features. However, I do not see that feature available within the list. Is there something I need to do to add this feature to the available list?
Nathan Phillips
June 13, 2024
Hello @Scott Simpson,
Would you be able to tell me what type of Project you are trying to enable the Issue Navigator within?
The Features you are referring to under Project Settings > Features are directly related to Jira Software Projects.
Although, the Issue Navigator is included by default in Jira Work Management Business projects by selecting the 'Issues' tab as seen in my example screenshot from a JWM Project in my test site:
More information on working with agile features in Team Managed Projects can be found here
Scott Simpson June 13, 2024
Thank you, but this has been resolved.
We were able to find the issue navigator in JSM and utilize filters to extract the reporting we needed.
Thanks for your time.
Like Nathan Phillips likes this
Nathan Phillips
June 13, 2024
@Scott Simpson
Awesome to hear!
If you by chance have a moment to share your resolution here on this post that would be greatly appreciated as it might help the next User.
Thanks!
