How to execute auto transition in jira workflow from one status to another status
Shivaprasad Hattaraki
I have one script field called  "Warranty Date Status" its value returns in HTML format( Valid  or Invalid),depending on these values i have to make auto transition from status "INPROGRESS" TO "VALID DATE" or  "INVALID DATE".
Could You please help me out for this?
I have tried with Toolkit plugin but didn't work.
Suhas P
June 18, 2018
It depends how the value of scripted field changes. Either you fire a custom event upon value set OR configure a Escalation service which will run in intervals to check the value and runs a script which transitions the issue.
Have a look IssueService class for triggering the transition from script. I will try to make a script when I have time :)
IssueService.TransitionValidationResult
def issueManager = ComponentAccessor.issueManager
def customFieldManager = ComponentAccessor.customFieldManager
def warrantyField = customFieldManager.getCustomFieldObjectByName("Valid Warranty Date")
def warranty = issue.getCustomFieldValue(warrantyField)
def systemDate = new Date()
if(warranty == null){
return("<p style=color:blue>Please Enter Valid Warranty Date</p>")
}else if(warranty < systemDate)
return("<p style=color:red>INVALID</p>")
}else
return("<p style=color:green>VALID</p>")
I have this code in script field based on these values i need to transit status automatically from "IN PROGRESS" to "VALID DATE" or "INVALID DATE".
could we able to do this using listener or not plz let me know if possible.
Hi Suhas,
Could you plz help me in  this issue?
Suhas P
June 19, 2018
i think in the same script you can put code in IF statement to transition the issue. Transition issue code looks like this.
Try following code. Use respective transition ids in both if statements. You can find transition IDs in transition name. they are written in brackets (11) like this.
def issueService = ComponentAccessor.getIssueService()
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def issueInputParameters = issueService.newIssueInputParameters()
issueInputParameters.with {
setSkipScreenCheck(true)
def validationResult = issueService.validateTransition(user, issue.id, transitionID, issueInputParameters) //actionID is transition id, you can see it in the workflow
if (validationResult.isValid()) {
// Perform the transition
def issueResult = issueService.transition(user, validationResult)
def validationResult = issueService.validateTransition(user, issue.id, transitionID_2, issueInputParameters) //actionID is transition id, you can see it in the workflow
}else
 have tried but not working.
I have tried with script listener but not working.
Suhas P
June 20, 2018
Its syntax errors I guess. have you tried adding those missing brackets { s? I have updated now.
yaa i have tried with adding  those brackets { but not working.
return warranty > systemDate
Could you make transition for this?
Value returns true or false boolean values.
if it returns true the transition validate date(21) action id has to perform else invalidate(31) action id has to perform.
