From Jira, is it possible to export (into excel/csv/word etc) all issues from within a particular project?
Just go to Search issues , advance search: project = SampleProyectScrum
And then you have the export options,
Glad I help!
The export is limited to 1,000 issues. If you have more you will need to do multiple exports.
Thanks Joe, no I don't have that many issues, but don't know how to process the actual export? Are there any steps you could point me toward that I can follow?
Thanks again
There is documentation in JIRA or just google it. The first step is to create a filter that returns the issues. There is an option to export on the filter results. Comments will not be exported.
I have more than 1k issues that needs to be exported.. Can you please suggest me some steps for such export? I am unable to figure out the number of issues even, it is just showing 1000+ that's it.
Please sort it out Joe.
Thanks in advance.
Akbar.
I've never had that problem. Add another condition in the filter like date to limit the number found. You'll just need to create multiple filters to export.
Hello -- related question:
When you export, does that export the attachments saved within the Jira?
It will export the file name and URL of the image, not an actual asset (like a .png file)
