Hi all,
I'm using Jira DC and I need to export issue links info for all bugs linked to a specific stories scope.
I have 4 Themes that I'm following to for reporting purposes. Our hierarchy is Theme > Initiative > Epic > Story. I need to export all bugs linked by a "is blocked by, relates to, etc" to the Stories below my 4 Themes.
Do anybody knows how I could filter this in my API export to excel ? Many thanks for the help :)
You could try something like below.
issuetype = Bugs AND issueLinkType in ("is blocked by","relates to")
Hi Tim,
Thanks for your answer but actually the problem is that I only want to export bugs that are linked to stories that are above specific themes.
For example I have :
- Theme 101 > Initiative 102 > Epic 103 > Story 104
- Theme 201 > Initiative 202 > Epic 203 > Story 204
- And so on
Then, I have :
- Bug 999 blocking Story 104
- Bug 888 relates to Story 104
- Bug 777 relates to Story 204
I'd like to know how to target and export those bugs (777, 888 and 999), knowing that I have 4 themes for 400 initiatives and many many Stories.
I previously used issuekey in childIssuesOf for searching all the Initiatives, Epic and Stories below my 4 Themes, so I was hoping there was a similar solution for Linked Issues :)
Actually, If I understood correclty, what I need would be IssueFunction in LinkedIssuesOf(Subquery) from ScriptRunner ...
Problem is I don't have admin rights and no possibility to have them. So I'm looking for ANY solution that don't include admin rights
It is not clear what is the output spreadsheet layout you're looking for, but Better Excel Exporter can export to a matrix-like overview like this:
Or, as @Tim Perrault suggested, if you can write a JQL query that collects the issue you're looking for, then you can export those from Issue Navigator.
Hello @Aron Gombas _Midori_
Can you send me your template for above picture?
I can't find how to refer to the issue links.
Please, help me fast.
Kudos
