How to extract custom fileds data from JIRA?
sudhir kumar rai July 29, 2022
Although we can export the custom fields data in .csv format, but is there any other way to extract custom fields data through automation, may be using REST API or Using JIRA connector in Azure Data Factory?
Ismael Jimoh
July 29, 2022
Hi @sudhir kumar rai ,
You could search for the issues using JIRA Rest API and specify that you want all field as described here.
I am unfamiliar with the connector to Azure unfortunately so I can't provide information on this.
sudhir kumar rai August 2, 2022
Hi Ismael,
Can you guide me on how to extract "JIRA issues (including custom fileds)" using rest API.?
