×Hi, relatively new to writing JQL but I need to find a way to search for all the issues in other projects that are impeded by our project.
So far I've come up with the following:
project in (Other Projects) AND issueFunction in linkedIssuesOf("Project = Our Project", "is blocked by") OR issueFunction in linkedIssuesOf("Project = Our Project", "is depends on")
I get the following issue:
Error in scripted function: linkedIssuesOf, see below
NoViableAltException(59@[])
Looking at other questions I haven't seen a clean way to do this without the use of a plug in. Is there any know workaround to this limitation?
Thank you!
Hi @Aisha Apps and welcome to our Community!
I believe the similar question has already been answered:
ScriptRunner throwing NoViableAltException
Please, see the answer by @JamieA
Hope this helps.
Thanks! I used the single quote fix as suggested but now I'm getting another error..
MismatchedTokenException(-1!=39)
Wow that worked, fantastic thank you.. I guess I just needed to be pointed in the right direction.
Glad it worked :)
You're always welcome here. Don't hesitate to ask should you have any difficulties.
Have a nice day!
@Aisha Apps Please note that the solution provided to you is available only if you have the licensed plug-in 'Adaptavist Scriptrunner for JIRA'.
