I'm working on a post-function, which is called at the end of the "create" transition. I need to know, if the issue is a clone of another issue, but the issue links are not yet stored in the data base and
issueLinkManager.getLinkCollectionOverrideSecurity(Issue issue)
returns an empty collection. Is there another way to find out, if an issue is a clone?
The only way I found, was to check for the parameter "pkey" in the transientVars provided by the execute method.
transientVars.containsKey("pkey")
This parameter is only set on create, not on clone. But I'd rather have a more reliable way to find out, if an issue was cloned or related...
Hi Christian,
How can we get "transientVars" parameter in issue create event?
you need to create a post function module. https://developer.atlassian.com/server/jira/platform/creating-workflow-extensions/
The "transientVars" are available in the execute method:
public void execute(Map transientVars, Map args, PropertySet ps) throws WorkflowException {
Try to put this post function last in the list of the post functions in the create transition
thanks for your answer, but the post-function is already the last in the list
