How to find project leads for issues with a specific resolution?
Karl Todd Jr
I need to isolate the email addresses of the project leads, but only for projects that have an issue with a specific resolution. What is the best way to get this information?
Ismael Jimoh
October 29, 2019
Hi @Karl Todd Jr
Firstly, note that resolutions are project wide unless you remove it in your workflow property.
Now to find the project admin do the following
  1. search for issues using the resolution and order by project
  2. go to the projects page preferably admin view since it lets you see all project
  3. the page contains the name of each project lead and you can view each user for their email.
Cheers.
jrtodd
October 30, 2019
Ismael,
Thanks for answering my question! But I am a little disappointed at the answer.
There are many, many affected projects. Is there no way to automate the gathering of this information? Or will I have to do this manually?
Ismael Jimoh
November 3, 2019
You could attempt doing what I described above with REST API or DB query which will both be faster.
As for automating, I do not have a clue how you can achieve this.
Cheers.
