×I need to isolate the email addresses of the project leads, but only for projects that have an issue with a specific resolution. What is the best way to get this information?
Firstly, note that resolutions are project wide unless you remove it in your workflow property.
Now to find the project admin do the following
Cheers.
Ismael,
Thanks for answering my question! But I am a little disappointed at the answer.
There are many, many affected projects. Is there no way to automate the gathering of this information? Or will I have to do this manually?
You could attempt doing what I described above with REST API or DB query which will both be faster.
As for automating, I do not have a clue how you can achieve this.
Cheers.
