I use vagrant to setup a docker container with the following lines
d.run "jira",
image: "atlassian/jira-software",
args: " -p 8084:8080 -m 2GiB" +
" --network jiranet" +
" -e ATL_PROXY_NAME=192.168.50.4" +
" -e ATL_PROXY_PORT=8084" +
" -e ATL_TOMCAT_CONTEXTPATH=jira"
During setup I get the following RuntimeIOException.
com.atlassian.jira.util.RuntimeIOException: Error writing database configuration file. at com.atlassian.jira.config.database.AbstractJiraHomeDatabaseConfigurationLoader.saveDatabaseConfiguration(AbstractJiraHomeDatabaseConfigurationLoader.java:74) [classes/:?] at
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) [tomcat-util.jar:8.5.42] at java.lang.Thread.run(Unknown Source) [?:1.8.0_232] Caused by: java.io.FileNotFoundException: /var/atlassian/application-data/jira/dbconfig.xml (Permission denied) at java.io.FileOutputStream.open0(Native Method) [?:1.8.0_232] at java.io.FileOutputStream.open(Unknown Source) [?:1.8.0_232] at java.io.FileOutputStream.<init>(Unknown Source) [?:1.8.0_232] at java.io.FileOutputStream.<init>(Unknown Source) [?:1.8.0_232] at java.io.FileWriter.<init>(Unknown Source) [?:1.8.0_232] at com.atlassian.jira.config.database.AbstractJiraHomeDatabaseConfigurationLoader.getWriter(AbstractJiraHomeDatabaseConfigurationLoader.java:89) [classes/:?] at com.atlassian.jira.config.database.AbstractJiraHomeDatabaseConfigurationLoader.saveDatabaseConfiguration(AbstractJiraHomeDatabaseConfigurationLoader.java:70) [classes/:?] ... 150 more
Here the ls for the dir
docker exec jira ls -al /var/atlassian/application-data/jira
total 48
drwxr-xr-x 11 jira jira 4096 Nov 25 18:47 .
drwxr-xr-x 1 root root 4096 Nov 20 21:16 ..
drwxr-x--- 3 jira jira 4096 Nov 25 18:45 caches
drwxr-x--- 3 jira jira 4096 Nov 25 18:45 data
drwxr-x--- 2 jira jira 4096 Nov 25 18:47 database
-rw-r--r-- 1 root root 999 Nov 25 18:45 dbconfig.xml
drwxr-x--- 2 jira jira 4096 Nov 25 18:45 export
drwxr-x--- 4 jira jira 4096 Nov 25 18:45 import
-rw-r----- 1 jira jira 0 Nov 25 18:45 .jira-home.lock
drwxr-x--- 2 jira jira 4096 Nov 25 18:47 log
drwxr-x--- 5 jira jira 4096 Nov 25 18:45 plugins
drwxr-xr-x 2 root root 4096 Nov 25 18:45 __pycache__
drwxr-x--- 3 jira jira 4096 Nov 25 18:45 tmp
Hi Frank,
I see that you're using a Jira Server inside a docker container and you can't seem to get Jira to start up. Thanks for posting all this information. I can see exactly what the problem is.
Jira is setup to run as a local user called 'jira'. However the dbconfig.xml file has been created and is owned by the user 'root'. Hence the jira user can't see this file to use it on startup. As such you will need to change the permissions on that file back to the jira user. Steps to do that are in How to fix directory permissions in Linux for Jira Server.
Go to a terminal prompt and run this command to see which user account is logged in:
whoami
If you are logged in as the jira user, then run
id -g -n
In order to find the name of that group.
With that information you can then run the following to give that jira user permissions on all the files in the needed directories:
sudo chown -R jirauser:jiragroup /path/to/jirahome
sudo chown -R jirauser:jiragroup /path/to/jirainstall
chmod -R u=rwx,g=rx,o=rx /path/to/jirahome
chmod -R u=rwx,g=rx,o=rx /path/to/jirainstall
Where you will have to input the jirauser, jiragroup, as well as the $JIRAHOME/ and $JIRAINSTALL/ paths in your environment here.
Once that is done, you should be able to start up Jira and move past this problem.
Let me know if you have any questions about this.
Andy
HI Andy,
my docker hast is a virtual box installed by vagrant. So the user and the group are vagrant.
this is my setup
config.vm.provision "shell", inline: "/vagrant/jira/presetup.sh"
config.vm.provision "docker" do |d|
d.run "jira",
args: " -p 8084:8080" +
" -v jiraVolume:/var/atlassian/application-data/jira"
end
Here the presetup.sh
#!/bin/bash
volName=`docker volume list | grep "jiraVolume" | awk '{print $2}'`
if [[ ! -z "$volName" ]]
then
echo "delete volume $volName"
docker volume rm $volName
fi
docker volume create --name jiraVolume
Last month I got the error but now the dbconfig.xml is owned by user root and now the user is jira. and the database setup finish correctly.
Now the file __pycache__ is the only file with user is root.
Think that this was fixed in the image now.
Frank
