×I have a post-function that sends a POST request from Jira to BMC Remedy, I can do the request successfully but I don't know how can I get the SOAP response?
I should be getting a value which is the Change ID along with the Error Code and Error Description.
This is a sample response that I should receive:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"> <soapenv:Body> <ns0:CreateResponse xmlns:ns0="urn:JR_Create">
<ns0:ChangeID>CR1000</ns0:ChangeID> <ns0:ErrCode>OK</ns0:ErrCode> <ns0:ErrDesc>Successful</ns0:ErrDesc>
</ns0:CreateResponse> </soapenv:Body> </soapenv:Envelope>
How can I get the response right after I sent the request successfully?
I'm trying to follow this example, but I'm getting too many errors:
def client = new SOAPClient("http://...") def response = client.send(SOAPAction: "SomeAction", connectTimeout:5000, readTimeout:10000, useCaches:false, followRedirects:false, sslTrustAllCerts:true) { version SOAPVersion.V1_2 // SOAPVersion.V1_1 is default soapNamespacePrefix "SOAP" // "soap-env" is default encoding "ISO-8859-1" // "UTF-8" is default encoding for xml envelopeAttributes "xmlns:hr":"http://example.org/hr" header(mustUnderstand:false) { auth { apiToken("1234567890") } } body { GetWeatherByZipCode(xmlns:"http://example.weather.org") { ZipCode("93657") } } }
You say you are getting too many errors in the provided example, but you also claim that you can do the request successfully.
Can you share how you do this successful request? Is it using a different code example?
If you can load the "response" variable correctly and it is loaded with an xml that matches the response you shared, I would expect that you should be able to get the change ID with
def changeId = response.Body.CreateResponse.ChangeID
Hello Peter, sorry for the late reply.
This is how I do the request:
def client = new SOAPClient("webservice URL")
def request = client.send(SOAPAction: "CreateOperation", """soapenv:https://schemes.xmlsoap.org/soap/envelope/"
xmlns:urn="urn:CreateRFC">
<soapenv:Header>
<urn:AuthenticationInfo>
<urn:userName>username</urn:userName>
<urn:password>password</urn:password>
<urn:/AuthenticationInfo>
<soapenv:Body>
<urn:CreateOperation>
<urn:Title>${title}</urn:Title>
<urn:Description>${description}</urn:Description>
</urn:CreateOperation>
</soapenv:Body>
</soapenv:Envelope>""")
log.debug(request)
Basically, what my request does is to create an RFC in Remedy, and my request works successfully. However, I'm not sure how I can get the Change ID in the response.
In the XML, there is another method for getting the response which is "CreateOperation_Response" wherein I can get here the Error Code, Error Description, and Change ID.
Can you help me how can I achieve getting the response using this?
def changeId = response.Body.CreateOperation_Response.ChangeID
Try adding
log.debug groovy.xml.XmlUtil.serialize(request.body)
This will confirm that the .send() method worked and received a wslite.soap.SOAPResponse and show you the full xml of the body
Then assuming the response match the XML you provided above, you should see that the first node in your xml: ns0:CreateResponse
So try to go down one level deeper:
log.debug groovy.xml.XmlUtil.serialize(request.body.CreateResponse)
And so on... until you get
request.body.CreateResponse.ChangeID
If you are not sure what the node names are you can always temporarily output
log.debug request.body.childNodes()*.name()
Omg thank you so much! I'm getting the Change ID now.
Can't believe this is the only line I needed to get the response lol.
