×Hi All,
I have client requirement to get all the issues related to particular project using this rest API.
https://itc-cloudio.atlassian.net/rest/api/2/search?jql=project="RUT"
API is working as expected but it is showing like this.
But Response showing
"expand": "schema,names",
"startAt": 0,
"maxResults": 50,
"total": 160,
How to get total total number of issues.help.
I have to consume this api in java.
Nageswara
I guess the total:160 meanst that you have 160 issues, which satisfy your JQL search
I need total number :160.In my response i am unable verify all 160 issues.Is this api gives 160 issues .please clarify.that should be great.
Do you mean that there are only 50 issues returned? If so, you can increase the number of the returned issues: maxResults = 100. But it is still less then 160. You need to call the REST API in iterations using the startAt parameter. You can find more info about parameters here:
https://developer.atlassian.com/cloud/jira/platform/rest/#api-api-2-search-get
Hi Alexey
How to provide this maxResults, and startAt parameter the above rest API?.
Please provide me one example
https://itc-cloudio.atlassian.net/rest/api/2/search?jql=project="RUT"&maxResults=100&startAt=101
Hi Alexey,
I have tried this same API:/rest/api/2/search?jql=project="RUT" & maxResults=160.
But getting response like this.
"startAt": 0,
"maxResults": 50,
"total": 160,
"issues": [
Is this response contains 160 records?
Please clarify.if this response contains 160 records.I am ok .
Nageswara K
The API can only return 100 results at a time, so your initial call of
will return the first 100 items. In your code, you need to check that the total value is greater than 100, then do another call, as @Alexey Matveev said, with
which will return items 101 to 160 (up to 200).
If you have more than 200 items, you will need to do a third call with startAt set to 201 to get them.
Hi Warren and Alexy.
Is there any Rest API to pull all issues based on the project.Please provide me .
I am new to this system.
I think we've answered your question!
What you were doing, with the changes suggested by Alexey and myself, will give you all the issues for a project.
You may be asking a different question, but the way I'm reading it, we've answered it.
