Hello Guys,
at the moment, I'm writing a script where I do an export of all users in a project (including groups). The Main problem is, that I don't know how to get the user of a project. With the project Manager, I'm not able to access them. Has anyone an idea?
Gauthier
Hi @Gauthier Gaukel Run below script in Script Console to get users in Project role, groups in project role and users which are having via user group :-
Basic the script is running a sql query and a result giving a table, kindly update project key as per your requirement.
SQL query source :- https://confluence.atlassian.com/jirakb/retrieve-a-list-of-users-assigned-to-project-roles-in-jira-server-705954232.html
import groovy.sql.Sql
import org.ofbiz.core.entity.ConnectionFactory
import org.ofbiz.core.entity.DelegatorInterface
import java.sql.Connection
def delegator = (DelegatorInterface) ComponentAccessor.getComponent(DelegatorInterface)
String helperName = delegator.getGroupHelperName("default")
def sqlStmt = """
SELECT p.pkey as "Project key", pr.name as "Role name", u.lower_user_name as "Username", u.display_name as "Display name", u.lower_email_address as "e-Mail", null as "Group name"
FROM projectroleactor pra
INNER JOIN projectrole pr ON pr.ID = pra.PROJECTROLEID
INNER JOIN project p ON p.ID = pra.PID
INNER JOIN app_user au ON au.user_key = pra.ROLETYPEPARAMETER
INNER JOIN cwd_user u ON u.lower_user_name = au.lower_user_name
WHERE pra.roletype = 'atlassian-user-role-actor'
AND p.pkey = 'VYT'
UNION
SELECT p.pkey as "Project key", pr.name as "Role name", cmem.lower_child_name as "Username", u.display_name as "Display name", u.lower_email_address as "e-Mail", cmem.lower_parent_name as "Group name"
INNER JOIN cwd_membership cmem ON cmem.parent_name = pra.roletypeparameter
INNER JOIN app_user au ON au.lower_user_name = cmem.lower_child_name
WHERE pra.roletype = 'atlassian-group-role-actor'
AND p.pkey = 'VYT'
ORDER BY 1, 2, 3;
Connection conn = ConnectionFactory.getConnection(helperName)
Sql sql = new Sql(conn)
String result = """
<table>
<tr>
<th>Project key</th>
<th>Role name</th>
<th>Username</th>
<th>Display name</th>
<th>e-Mail</th>
<th>Group name</th>
</tr>
sql.eachRow(sqlStmt){ it ->
result += """
<tr>
<td>${it.getAt("Project key")}</td>
<td>${it.getAt("Role name")}</td>
<td>${it.getAt("Username")}</td>
<td>${it.getAt("Display name")}</td>
<td>${it.getAt("e-Mail")}</td>
<td>${it.getAt("Group name")}</td>
</tr>
return result+"</table>"
sql.close()
