How to get custom fields with values using SQL Iin jira
Bhargavi Vasa
I am looking for SQL to get custom fields with values in jira for issues
Jira version : 8.20.5
Projectkey,issuekey,customfieldname,customfieldid,customfieldvalue
Kris Dewachter
Hi @Bhargavi Vasa ,
Can you describe more in detail on what you are trying to achieve ?
You can use JQL to find the issues you need, and configure the columns in the list view.
Best regards,
Kris
Bhargavi Vasa
I am looking for SQL to get custom fields in a project with their values for all the issues in that project
Kris Dewachter
July 16, 2024 edited
The quickest way to do it to export the issues via JQL. Export the issues to an Excel or CSV file with all fields. You can select the information you need from within the Excel file
