Hello team,
I have added one validation for one field while creating the Issue (issue type = Bug).
if ((issue.issueTypeObject.name == 'Bug') && !cfValues['Regression Bug']) {
return false;
} else {
if (cfValues['Regression Bug']?.value == 'Could not be checked' && !cfValues['Regression Bug Comment']) {
return false;
return true;
Now for one another field I need to check the user is developer and field value is "NOT SET" otherwise return false.
I will add this code in simple scripted validator.
Please help me with this.
Suhas
Hello Suhas,
To find the project role you can use the following:
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.security.roles.ProjectRoleManager
def projectManager = ComponentAccessor.projectManager
def projectRoleManager = ComponentAccessor.getComponent(ProjectRoleManager)
def allProjects = projectManager.getProjects()
def project = allProjects.find(){it.getName() == "Project Name"}
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def projectRoles = projectRoleManager.getProjectRoles(user, project)
def memberOf = projectRoles.find(){it.getName() == "Developer"}?true:false
if (memberOf){
*Do stuff*
I am not sure what you mean with field value is not set. Is it a select field with the option "NOT SET" or is it null?
Yes, its a field with value "NOT SET".
So you saying the above code will work in simple scripted validator?
Hi Raskou
I have achieved this using following:
if ((isUserMemberOfRole('Developers')) && cfValues['Management Flag']!= 'NOT SET') {
return false;
return true;
Thanks for your help!
Suhas
Hello Suhas,
That's great, glad you got it working!
