How to get tables to work from Jira Automation to Microsoft Teams (using Power Automate/Flows)
James Prieto October 1, 2024
I used to be able to pass tables from Jira Automation to Microsoft Teams using the format:
| Col 1, Row 1 | Col 2, Row 1 | Col 3, Row 1 |
| Col 1, Row 2 | Col 2, Row 2 | Col 3, Row 2 |
This used to work (when using Connectors) and would result in a formatted table in Microsoft Teams.  However now that I am using Power Automate/Flows, it comes unformatted.  Does anyone have any tips in getting this to work?
Thank you!
Jan Westphal
Hello @James Prieto
The Format is a little different, here is an example you can try:
||*Manufacturer Part Number / Ordering Code*||*Manufacturer*||*Quote*||*Quantity*||*Quote Date*||*Quote Number*||*Supplier*||*Lead Time*||
||*X*||*Y*|| || || || || || ||
This will result in the following table:
basically you use || for a new column and use it twice for a new line.
Best regards,
Jan
James Prieto October 2, 2024
Thank you @Jan Westphal, is that meant for an output into Microsoft Teams? I still get the same output in Teams and it isn't a table.Screenshot 2024-10-02 at 8.30.45 AM.png
tgurukunta November 19, 2024
Any luck on getting this work ? Facing the same issue, not able to create the table
Like James Prieto likes this
James Prieto November 19, 2024
No, I cannot get tables to work.
