How to get the current item index using Smart Values
Mohamed Adel
May 20, 2021
I would like to get the current index for a list of items using smart values
According to the documentation i can get the first/last and iterate over all items , but i don't find a way to get the current index
https://support.atlassian.com/jira-software-cloud/docs/smart-values-lists/
Martin Bayer [MoroSystems, s.r.o.]
Hi @Mohamed Adel , you can access index and you can find it in the documentation you shared. Screenshot attached :)
Mohamed Adel
September 28, 2021
Thanks @Martin Bayer [MoroSystems, s.r.o.]  for your reply , I got the solution at this time but forget to close it :D
Ok :D if you think this topic and my answer can help someone else, it would be kind of you if you accept the answer...at least it will be marked as solved :D
Eric Bergeron
Hi @Martin Bayer [MoroSystems, s.r.o.] ,
Would it be possible to get an example how to use the {{#list}}{{index}}{{/}} ? How would you use it, say for a custom field?
I'm trying to extract the value of the currently selected item of the list (and then convert it to a numerical form).
Like 石川諒 likes this
