How to get the latest comment from an issue in Jira?
Edilson Hernandez Serpa
April 24, 2023
Hi community!
I need to filter the latest commment from an issue (epic,task,etc.) because I want to generate a report automatically.
Thanks!!
2 accepted
3 votes
Mikael Sandberg
You could do this by creating an automation and then use {{issue.comments.last.body}} to get the last comment.
April 25, 2023
Hi Mikael
Thanks for your answer!
I am trying to do a JQL query with that smart value and I am having problems. My idea is to do a query because I want to make a Confluence page and have the reports automatically. I am trying this:
project = POR39505 AND summary ~ "Book project" AND issuetype = Epic AND "comment ~ {{issue.comments.last.body}}"
I need to extract the last comment from that epic. If you can give me some advice on this, I will be very grateful
Thanks!
Sherwin Soriano
@Mikael Sandberg How do you configure this on the automation rule, I mean where is the output, is it via email? just curious
Mikael Sandberg
@Sherwin Soriano you can use the smart value as part of the email content, something like this:
Here is the last comment on the request:
Sherwin Soriano
@Mikael Sandberg
a little help, how do you configure the rule? I mean what is the trigger or how does the structure of the rule will start?
Also, is it possible to like create a new field and then update the {{issue.comments.last.body}} in that field every time a new comment is added? is this possible?
Mikael Sandberg
@Sherwin Soriano My automation was setup to trigger on the transition, so for example when it transitioned to Finance approval the automation checked if the Finance approvers field was empty of not, and if it was then the automation approved it so that the ticket kept on moving in the workflow.
Hannes Obweger - JXL for Jira
Hi @Edilson Hernandez Serpa
if you're open to solutions from the Atlassian Marketplace, this would be easy to do using the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a large number of so-called "smart columns" that aren’t natively available, including the latest comment (along with many other comment-related columns).
This is how it looks in action:
As you can see above, you can easily view, sort, and filter by the latest comment, and also add new comments, either on a single issue or in bulk via copy/paste. You can also use the latest comment across JXL's advanced features such as (configurable) issue hierarchies, issue grouping, sum-ups, or conditional formatting.
Best,
Hannes
