The Stages should be selected based on the Environment.
ie., Based on the Environment selected, the Stages should be changed.
For example, Environment "XYZ" will have Stages 1, 2, 3
Environment "ABC" may have stages 1, 4, 5
Can anyone help with a solution for this.
Create a custom field called "Environment/Stage", of type "Cascading Select". You can then specify your Environment as the first level of the select field, and Stage as the second level, based on the selection in the first.
Hi Pete Singleton,
Thank you for your response. Tomorrow first thing I will try your proposed solution.
Thanks again.
Sri.
Hi @Sri Chavali ,
Environment and stage are custom fields? Do you want to do a cascade on two field selections?
