How to give connection between two custom fields in JIRA?
Anusha Bandaru October 20, 2017
We are created two custom fields "Location" and "Places".
If i select one particular value in "Location" only related values are shown in "Places" Field.
Nic Brough -Adaptavist-
October 21, 2017
Natively, you should use a "cascading select list" to do that.
But if you want a link between two separate fields, you're going to need add-ons to impose it.  The obvious one is the "Behaviours" module in Script Runner
Anusha Bandaru October 21, 2017
Thanks for your response.
I want to give logic connection between default field and custom field.
Joe Pitt
That isn't the original question. It was 2 custom fields. Neither location or places is a default (system) field.
Cascading select list is helped with two custom fields.
I am having another requirement having one custom field and one default field.
October 21, 2017
If you want a link between two separate fields, you're going to need add-ons to impose it.
