How to grant a developer to create an issue in a project?
Laurent Houdusse January 12, 2023
I a project administrator and i want to grant developpers to create issues.
In Project settings\Permissions for "Create Issue", I have
  • Project Role (atlassian-addons-project-access)
  • Application access (Any logged in user)
but developpers cannot create issue.
There is an error : "User doesn't have the "Manage projects" permission".
I don't want set the "Administer projects" permission to a developper.
how can i do?
Trudy Claspill
Hello @Laurent Houdusse
Where is the error message being displayed? What actions are being executed and who is executing them?
What steps are the developers going through to try to create issues?
Is the project a Company Managed project or a Team Managed project? It will say which it is in the bottom left in the navigation pane.
Is it a Service project, a Software project, or a Business/Work Management project?
Are the users able to see issues in the project? Are they able to take any other actions on the issues, like editing them or adding comments?
The error is displayed in the "Create issue" popup when a user logged with a developper account on the project "BORA Connect" want to create  an issue
The project is a company managed software project
Developpers can see issues in the project and can change issue status and adding comments
Trudy Claspill
Could you try using the Permissions Helper to try to zero in on why Jira has determined that the Manage Projects permission is needed?
https://support.atlassian.com/jira-cloud-administration/docs/use-the-jira-admin-helper/
The permission should not be needed for simply creating issues. Typically Browse Projects and Create Issues is sufficient.
Can you tell us what fields are available in the Create Issue screen, and which fields the developer is setting?
The Permissions Helper says that the devlopper has the Create Issue permission and the Browse Projects permission. I don't find a Manage projects permission in the list but perhaps i mistranslated and it's "Administer Projects"
The developper set the description, the sprint and assign to him
Trudy Claspill
Can you show us the full output of the Permissions Helper?
Laurent Houdusse January 13, 2023
Here the output
Fields available are
  • Project
  • Issue type
  • Summary
  • Reporter
  • Description
  • Priority
  • Linked issue
  • Assignee
  • Sprint
And developper set
  • Project
  • Issue type
  • Summary
  • Reporter
  • Description
  • Priority
  • Assignee
  • Sprint
Trudy Claspill
For an already existing issue is the user able to edit all the fields that they are trying to set when creating an issue?
Laurent Houdusse January 18, 2023
Hi @Trudy Claspill
Sorry for the delay of this answer.
The user can edit all fields. After tests, I find that user can create issue of another type.
The issue type that cannot be created has the same sreen scheme, the same field configuration but has a different workflow.
What could create the error at the workflow level?
Trudy Claspill
There may be a Validator on the Create transition in the workflow for that issue type. You will need to Edit the workflow to investigate this.
You might want to make a copy of that workflow to open in Edit mode, rather than opening the original workflow in Edit mode.
Once you have the workflow open in Edit mode, find the Create transition. It will be between a circle and the initial status that your newly created issues use.
Click on that arrow/transition and you'll see a pop up display.
Click on Validators in that pop up and you'll see another screen display something like this.
It is here that another Jira Administrator may have added another Validator to limit the creation of this issue type to only people who have a certain permission or belong to a certain role. By default, the Validators for a Create transition will look like what I've shown, but it is possible that it was modified in your environment in this specific workflow.
Laurent Houdusse January 19, 2023
Hi @Trudy Claspill
Thank you very much for your help.
We had a validator "Only users with Administer Projects  permission can execute this transition".
After removing it, it works
Sushant Verma
Hi @Laurent Houdusse
You need to provide the permission to developer to create an issue.
 Below is the document how you can manage permission:
https://confluence.atlassian.com/adminjiraserver/managing-project-permissions-938847145.html
Sushant Verma
Have you seriouslly read my question?
Sushant Verma
@Laurent Houdusse  My bad!
