I have shared a custom field with a issue type but I want to change the custom field values to different issue type in the same project any way to do it?
You can create a different context for the field for each issue type and have different options in the dropdown for each issue type.
Go to Settings > Issues > Custom fields
Search for the custom field.
Click the 3 dots menu and select Contexts and default value
Click the link for Add new context and follow the steps
Yes but how to map same project with the two different contexts?
For example when I selected Project A in context 1
I am unable to Select Project A in context 2
that would be nice to have, i wondered the same, shame we cant do this.
Hi @vshnu raj ,
This is the limitation in the jira cloud and we can not add different context for different issue types in the same project and there is a support ticket is in progress since long time nut there is no update on it.
