Hi All.
I had comb through responses on how to be able to have a specific status only edited by the project admin role. i have tried various properties methods including the common suggested:
Property Key: Jira.issue.editable Property Value: False
Property Key: Jira.issue.editable.projectrole=10002 Property Value: True
The above method and it permutation doesn't seem to work.
Note: all status seem to be default editable in all our workflows.
Any help would be appreciated.
Hey @Jeff Parnell
What do you mean when you say "edit a status"?
Assuming you want only project admins to use transitions from status a to status b, you should limit the transition to the admin project role in the workflow by utilizing conditions.
Apologies if i understood you wrong.
regards
Sorry, that is a little confusing. What we mean is that we want only the project role "admin" group members to have the ability to edit an issue that is in a specific status in the workflow. We do not want to prohibit transitions to a status.
For example, if a issue was in the "made in error" status, only the project role admin group should have the ability to edit the content of the issue, not anyone else. Given what we have read, we should be able to do this by the properties function on a status in the workflow. However, the recommend properties listed in my initial request seems to not work.
Hope this helps.
Understood.
Does this article help? (You should be able to exchange jira.permission.edit.group.1 with jira.permission.edit.projectrole.1)
regards
Hi Michael
This method doesn't seem to work. I have tried the below.
Attempt 1:
Property Key: jira.permission.edit.projectrole.Administrators
Property Value: Administrators
Outcome: could not connect to the issue
Attempt 2:
Outcome: Everyone could edit
Attempt 3 (since edit is on for everyone for default in jira)
Property Valie: Adminsitrators
Property Key: Jira.permission.edit.Denied
Outcome: no one could edit
Attempt 4
Property Key: jira.permission.edit.projectadmingroup
Property Value: projectadmingroup
Outcome: everyone could edit
Attempt 5
Property Value: true
Attempt 6
Outcome: no one can edit
try:
Property Key: jira.permission.edit.projectrole.1
Property Value: ID_of_your_role
To get the id, navigate to Administration -> System -> Project Roles and hover over "Edit" on the desired role. It should show the id in the bottom left corner of your browser (where the target URL gets displayed)
regards
Yes. This worked! I assumed due to the wording in step 1 "group.1" was filler for the custom group, my mistake. Thank you so much. Your help is very much appreciated.
<3
If the answer turned out to be helpful, i would appreciate it if you could mark it as such so others can find it easier :)
have a great day!
