Let's say, I want to import issues from project a to project b with the attachments.
Is this possible to import issues with attachments?
I am trying to import and the data is importing but the attachments are not.
Kindly suggest me how to import issues with attachment
Hi @Soumyajit Pal ~ are you actually importing from one Jira instance to another or just moving issues between projects? If you're importing from a separate instance, refer here for more information with respect to attachments. If you're simply moving issues from one project to another in the same instance, you should just be able to use the "Move" option....
Hi @Laurie Sciutti ,
Thanks for your reply,
I want to merge two projects, for example,
There are two projects, Project A and Project B. And both projects contain issues. Now I want that all the issues of Project A should be there in Project B, like importing issues.
And also all the attachments should be imported with the issues.
Hi @Soumyajit Pal ~ if the two projects are on the same instance, then you don't need to import. You can just move. To do so, run your JQL (i.e. Project = "ABC") and then Bulk Change > Move. But it's not clear if that's the case for you. So refer to my previous response for the link to import from one instance to another.
Hello @Soumyajit Pal
If you're willing to use a third-party app, you can try our application Copy & Sync.
It will help you with that as you can copy all issues from one project to another, including all data like fields, comments, etc. and of course, in your case, attachments.
Let me know if you need more information, I'll be glad to help!
Regards
Thibaut
