How to include all issue types in "Default issue type scheme"?
Mariano Redondo
I´m trying to set "Default issue type scheme" for all my projects, but it only has "Epic" issue type assigned, and I need all standard issue types to be available.
When I edit the scheme, it does not show the "Available issue types" component, which it is present when editing any other scheme (see attached screen capture).
As a workarround I could create a new scheme, but I´d like to use the default.
Thank you.
Raynard Rhodes
August 3, 2018
When you go to Jira Administration > Issues > Issue Type Screen Schemes
When you click on "configure" for the default and "Associate an issue type with a screen scheme" is this what you see?isthisit.png
Mariano Redondo
Hello Raynard, thank you for your quick answer. I can´t find steps to get to that screen. When I clic on  Jira Administration > Issues > Issue Type Screen Schemes, I see the list of schemes and options for each are: Edit | Associate | Copy. If I edit, I see the screen I just added to my post, where there are no issue types to select.
If I clic on Associate, it shows me the list o projects assigned to any other schemes.
Raynard Rhodes
August 3, 2018
Hmm...there seems to be an option missing.
This is what I see when I get to the screen schemes.
Mariano Redondo
That´s weird. I don´t have the "Configure" option you have, and you don´t have the "Associate" option I have. However, I think my Edit option should work, as when editing any other scheme but the default I have all issue types available to select. Below an example.
Raynard Rhodes
August 3, 2018
Looks like we're not using the same Jira.
Eddy Fras
Hi Mariano,
Did you finally managed to include all issue types in your default ITS ?
I have the same problem on my Jira.
I don't understand why Raynard suggested to look at ITSS configuration ...
Eddy
Mariano Redondo
Hi Eddy. No, I haven´t been able to. I ended with creating another scheme as workarround.
Regards.
Eddy Fras
Hi Mariano,
Thanks for your answer.
Actually, it seems that it's a normal behaviour for Atlassian : https://jira.atlassian.com/browse/JRASERVER-59866?focusedCommentId=884853&page=com.atlassian.jira.plugin.system.issuetabpanels%3Acomment-tabpanel#comment-884853
But it's not consistent with the following KB article : https://confluence.atlassian.com/jirakb/issue-types-missing-blank-or-duplicated-in-issue-type-schemes-in-jira-server-226169285.html
So I don't understand Atlassian position ...
Eddy
