How to insert code (preformatted) in next-gen project issues
Paweł Kalinowski
April 1, 2019
When I try to insert code block in my next-gen project issue, I just see the code as a regular text.
It looks to me like "{{" and "}}" are just plainly ignored.
Does not matter whether I enter these manually or use "preformatted" option from "Style" drop-down.
Andrew Janke
April 1, 2019
This is broken. It's been that way for a while. I've submitted it as an issue to Atlassian support: JST-464545
Paweł Kalinowski
April 1, 2019
{{too bad I cannot see the issue, but I'm happy it has been reported. this is a big pain.}}
Larry Wilson
September 17, 2019
Yeah, for me, using Oracle SQL syntax, it removes all leading whitepaces, which makes code formatting really ugly.
paula December 19, 2019
Was there an issue create from your request that we can upvote? @Andrew Janke
