Hi Joe-
My name is Beth and I work for Tasktop. The answer to your question is yes! Let's jump on a quick call to discuss more details of your specific use case and how Tasktop can support your integration requirements.
Beth Beese | Tasktop Technologies phone: 647-938-3759
Hi Joe- Please let me know your email address or phone contact details so I can set up a call for us. You can also call me directly at 647-938-3759 Thanks!
Hi Beth,
We have a requirement to integrate JIRA with IBM RTC tool. What is the license cost if we have 50 licensed users in jira?
Sravani.
Hello Sravani-
Tasktop Integration Hub is licensed per user. Do you have some time to chat on the phone to confirm all the details? Let me know if you have some time tomorrow, before noon is fairly open for me.
Thanks and Best
BB
Please let me know your email address so I can set up a call for us. Thanks!
Hello Aylli-
You can see a video of how this integration works via Tasktop here
https://www.tasktop.com/integrations/ibm-rational-quality-manager
We are a technology partner of Atlassian, our integration solution is on the Atlassian Marketplace here
https://marketplace.atlassian.com/plugins/tasktop-integration-hub/cloud/overview
Please feel free to reach out to me if you have any questions or would like to learn more about Tasktop!
Thanks and Best
Hi Joe,
We are looking for the same kind of integration between RQM and JIRA. Please let me know if Tasktop worked well for you.
Hi Aylli - did you figure out a solution to integrate Jira with RQM?
This is for using JIRA as the defect management tool. RQM will be used for testing requirements and Defects will be created and maintained in JIRA.. So if test fails inside RQM we should be able to create a defect from RQM which will be stored in JIRA.
Is this possible.?
Hi Joe - how did you make out with this; did you end up using TaskTop or go another route?
Maybe you could expand on the requirement a little to explain what you're trying to do? What does "integrate" mean to you in this context?
