×Hi Jira Community,
I have set a custom field which is date picker and a system default field called updated. When I want to export these two I found that they all showing time h:mm a.
I notice that on look and feel page I set all the time format = YY/MMM/DD h:mm:a
I have also checked the advance setting which the date picker format is correct.
I want to let updated to display YY/MMM/DD h:mm a and let custom field to display YY/MMM/DD.
Please help. Thanks in advance!
Hi Tarun,
Thank you.
Seems like a known issue lasting for 3 years.
