×You can manually link a Jira issue to a Zephyr Scale test case by adding the Jira issue to the first line (or any line) of the script on the Zephyr Scale test player.
Also, if you are creating new Jira issues via CSV upload, you can link Jira issues using the "Coverage (Issues)" field under Traceability.
Finally, if you are trying to bulk edit linked Jira issues on a number of Zephyr Scale test cases, you can either add to or replace existing Jira issues under Zephyr Scale > Test Cases > More > Edit selected test cases in bulk.
Were you trying to use an API to bulk-link existing Jira issues to different Zephyr Scale test cases? E.g. you have a spreadsheet with the Zephyr Scale test case ID and associated Jira issues to be linked, and you are looking to have these linked using an API? This I have yet to attempt, lol
I am using Zephyer Scale Server. I have a solution for it. Please have a look below comments.
Welcome to the community!
Here's the documentation for Zephyr API
Didn't see anything in the documentation related to linking. So looks like the Zephyr Test cases are like Jira Issues where you probably could use just the Jira Api for linking tickets. See link below:
Thank you for responding. Anyways, it did not worked for me. I have raised a request with my query. If I get a answer or I will be able to solve it. I will share the solution here.
I got the solution, Here is curl , which worked for me.
curl --location --request PUT 'https://<Jira URL>/rest/atm/1.0/testcase/TestCase ID' \
--header 'Authorization: Bearer <Jira Auth Token?' \
--header 'Content-Type: application/json' \
--header 'Cookie: JSESSIONID=6003A2556E0CC3112B16007259E3648C; atlassian.xsrf.token=BIZK-WQVJ-ABWK-F14N_8c880f3406bab925b6d1af83c270350db5fdbf1a_lin; AWSALB=a8zxFKxgx7NxUm7jpfAM7Yb+ZApsLLBeWfiSO9YjyTgj+US1VXfQXRgDNTEKB2OfSCAXF1zTw1hms1GyzdQ11WagWi2pG/JVPFk6a2NZL1PI66r1Dgplbhxy5YDU; AWSALBCORS=a8zxFKxgx7NxUm7jpfAM7Yb+ZApsLLBeWfiSO9YjyTgj+US1VXfQXRgDNTEKB2OfSCAXF1zTw1hms1GyzdQ11WagWi2pG/JVPFk6a2NZL1PI66r1Dgplbhxy5YDU; JSESSIONID=E011958AF61BD69E755BF30D48B0454B; atlassian.xsrf.token=BQ1N-6AO8-TUVU-90JB_27b4f4f25e46bb34d82204dd9c492f3749370a62_lin' \
--data '{
"name": "Ensure the axial-flow pump is enabled",
"status": "Approved",
"issueLinks": [
"<Jira Story Id>"
