How to link issue as parent issue via automation
Dana.Harel
I created automation which:
  1. Edits a story to be an Epic
  2. Then - creates another task that should be linked under the Epic from step 1
Yet, it seems I cant link between issues
John Funk
Hi Dana,
Unless I am missing something, I don't see anywhere where you are creating the new issue - only updating the current issue.
Dana.Harel
Hi thanks
The 3rd screenshot is the creation of the new issue with a field of "Epic link" being copied from trigger issue
Dana.Harel
John Funk
Ah, thank you.
So, you will need another branch after you create the issue. It would be a branch for Most recently created issue. Then follow what Damian has below for Linking issues.
Dana.Harel
I would like the issues to be linked as child & parent link
Damian Wodzinski
August 4, 2022
You cannot create task as child item. You although can create subtask
Damian Wodzinski
August 4, 2022
