How to lock the editing permission of the specific field when switching to a specific status?
Cira Zhao
Hello Atlassian users,
I want to lock the editing right of the specific field of an issue to specific users when the issue is transitioned to a specific status. How can I set this?
Any assistance/thoughts are appreciated. Thanks!
Cira
Ollie Guan
Cira Zhao
Sorry, I didn't describe the problem clearly. My problem is to lock the edition right of the specific field of an issue to specific users when the issue is transitioned to a specific status. Is it possible?
Cira Zhao
Hi Ollie,
Thanks a lot for the prompt reply!
Cira
Like Ollie Guan likes this
Rilwan Ahmed
Hi @Cira Zhao ,
Welcome to the community !!
You can make use of Status properties like
  • jira.issue.editable - false
  • jira.permission.comment.denied - true or leave empty
To disable edits and comments at the Workflow level, you can follow the steps outlined below:
 Edit the workflow that will be restricted; (more details in https://confluence.atlassian.com/jirakb/disabling-edits-in-closed-issues-1139441852.html)
  1. On the workflow's diagram view, click over the status that you want to add the restrictions;
  2. You will see a popup menu on the right side of the screen;
  3. Click on "Properties" in the popup menu;
  4. Add the following properties;
  5. Publish the workflow changes;
    More clearly explained in https://jlabnotes.com/jira-workflow-properties-disable-issue-editing/
Also to know the available properties, you can refer: https://confluence.atlassian.com/adminjiraserver/workflow-properties-938847526.html
Cira Zhao
