×Hello Atlassian users,
I want to lock the editing right of the specific field of an issue to specific users when the issue is transitioned to a specific status. How can I set this?
Any assistance/thoughts are appreciated. Thanks!
Cira
Sorry, I didn't describe the problem clearly. My problem is to lock the edition right of the specific field of an issue to specific users when the issue is transitioned to a specific status. Is it possible?
You need plugins for workflow extensions.
Hi @Cira Zhao ,
Welcome to the community !!
You can make use of Status properties like
To disable edits and comments at the Workflow level, you can follow the steps outlined below:
Edit the workflow that will be restricted; (more details in https://confluence.atlassian.com/jirakb/disabling-edits-in-closed-issues-1139441852.html)
Also to know the available properties, you can refer: https://confluence.atlassian.com/adminjiraserver/workflow-properties-938847526.html
