I am looking to make Fix Version Required only for Issue Type Story.
Got some option of with Script, but all script running is Paid App.
Hi @Abdul Rahim
Welcome to the Atlassian Community! Without knowing anything soecific about your setup and needs, the simple sollution would be to create a field configuration where Fix Version is required. This field configuration could then be configured in the field configuration scheme of your project and mapped to the story issue type.
Hope this helps!
Thanks @Johan Markström for quick suggestion, its working for my requirement.
