How to make custom field in detail issues?
سید مصطفی مرتضوی November 2, 2019
Display it in the detail issues.
Avinash Bhagawati {Appfire}
Hi @سید مصطفی مرتضوی ,
You need to have board admin permission to configure issue detail view fields and Go to Board > Configure > Issue detail view > Add required fields.
Please refer below documentation for detailed steps on this.
https://confluence.atlassian.com/jirasoftwareserver/configuring-the-issue-detail-view-938845334.html
Avinash
i want show in .....2019-11-02_19-20-09.pngi want show custom field in the part
Please follow steps.
1. Go to Project Settings
2. Click on Screens , Screen Schemes and Screen.
3. Add the required field in the screen and create issue with value for field and test.
4. If you do not see custom field , then please check field context whether custom is configured for all projects or not.
Avinash
