How to make system fields mandatory on screens
Sherry Nightingale
I have created a project that the lead wants to make the majority of the fields mandatory
For the custom fields that just belong to this project i've ticked 'required'
For the custom fields that belong to multiple projects i've created behaviours
But for the system fields of Start Date & Due Date I can't figure out how these fields can be made mandatory?
Fazila Ashraf
Hi @Sherry Nightingale
You can control the field's mandatory/optional setup natively using the field configuration scheme.
https://support.atlassian.com/jira-cloud-administration/docs/specify-field-behavior/
Sherry Nightingale
Thanks @Fazila Ashraf
I've read through all of this and it doesn't explain how I can make a field (used by multiple projects) mandatory just on one project
The Project has it's own field configurations but there doesn't seem to be a way of making the Start Date and End Date (system fields) mandatory just in this one field configuration
Unless i've not understood what you've shared correctly
Sherry
Sebastian Krzewiński
Did you try to use Field Validator?
I think this can solve your issue.
Seba
Sherry Nightingale
Hey @seb
Would be great to understand a bit more about this - is it Out of the Box and available to everyone?
Do you have documentation you could share?
sherry
