How to manage recursive issues on JIRA?
Talib Usmani August 6, 2023
How we can manage recursive issues on JIRA? How they will be managed on the BOARD and how they will be generated after a specific period of time like daily, once a week, and once a month? What is the best way to manage such recursive issues?
Utkarsh Singh
August 7, 2023
Hi @Talib Usmani This screeshot should help-
Talib Usmani August 7, 2023
@Utkarsh Singh - Can we create an automation that say when a task is in done, create the same task in the TO-DO status in the same project?
Utkarsh Singh
August 7, 2023
Yup, use the trigger Issue transitioned-Screenshot 2023-08-07 at 7.29.49 PM.png
Here is the list of all triggers in the Jira cloud.
Like Talib Usmani likes this
Thanks @Utkarsh Singh
Sebastian Krzewiński
Hi @Talib Usmani
For repeating issues I'm using automation for jira (scheduled rule). I'm using it in many projects.
Seba
HI @Sebastian Krzewiński
Thanks for the response
Can you share that Scheduled Rule with me along with the explanantion?
@Talib Usmani
this is an example from automation library from Jira. You can use it.
@Sebastian Krzewiński - Can we create an automation that say when a task is in done, create the same task in the TO-DO status in the same project?
Hi @Talib Usmani are you able define what tickets should be create again? Without that it will be hard to achieve this.
Talib Usmani August 8, 2023
Yes, as the board only contains the recursive tasks so all the task that will be in done need to be created again.
FREE
