How we can manage recursive issues on JIRA? How they will be managed on the BOARD and how they will be generated after a specific period of time like daily, once a week, and once a month? What is the best way to manage such recursive issues?
Hi @Talib Usmani This screeshot should help-
@Utkarsh Singh - Can we create an automation that say when a task is in done, create the same task in the TO-DO status in the same project?
Yup, use the trigger Issue transitioned-
Here is the list of all triggers in the Jira cloud.
For repeating issues I'm using automation for jira (scheduled rule). I'm using it in many projects.
Seba
HI @Sebastian Krzewiński
Thanks for the response
Can you share that Scheduled Rule with me along with the explanantion?
@Sebastian Krzewiński - Can we create an automation that say when a task is in done, create the same task in the TO-DO status in the same project?
Hi @Talib Usmani are you able define what tickets should be create again? Without that it will be hard to achieve this.
Yes, as the board only contains the recursive tasks so all the task that will be in done need to be created again.
